Pyro simulation (Fuel on path)
   3596   3   1
Prompt who knows.
I have pyro simulation, its source fuel.
But when my source moves in space, it leaves a part of himself in the beginning of path. Why this happens? How get rid of this?
Edited by unitmotion - Jan. 16, 2017 17:47:00
fire.hip (949.3 KB)
If you visualize your fuel you will see that is not burning quickly enough. As long as the fuel exists combustion will occur. Try to find a way to either emit less fuel or burn it more quickly.
Or:
Change the Source Volume from Add to Copy then loosen up the drag on the particles..
Edited by Enivob - Jan. 16, 2017 22:01:40
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
It worked
Why is this happening
switch setting source smoke to fuel and i have more fuel
and I have to change the settings source volume to copy,
Why by default is add?
Edited by unitmotion - Jan. 17, 2017 06:26:33
I just wanted to say thank you for this post. I have been trying to figure out how to do this for some time now…I guess my lurking has paid off!
