How to Reverse corrective Blendshape?
   4894   10   2
Hi, Does anyone know how to do reverse blendshape? im not saying about the negative value.
I am using zbrush to sculpt the corrective shape on pose space. Then import as obj into houdini as blendshape. But how can I go to bind pose and still have the “corrected delta” to transform with the bones? the terms is usually call ‘reverse’ or ‘invert’ blendshape. Please see the image for clearer explanation.
The third image is what i want to to achieve.
(it was created in maya with a script http://www.chadvernon.com/blog/resources/cvshapeinverter [chadvernon.com] )
Thanks in advance
Use the -d option on the sopcreateedit [sidefx.com] hscript command.
edward
Thanks. I am new to houdini and now searching for how to use hscript and will try this script.
From the main menu, do Windows > Hscript Textport. Type in the appropriate command there with paths to your nodes.
edward
Thanks it works!
Now i have another question. How can I generate sopcreateedit for every frame?(400frames) base on current deform?
what is the formula behind sopcreateedit? perhaps i can replicate it through pointvop?
Edited by ruudygh - Jan. 25, 2017 23:09:13
Probably use a script that changes the frame and run the command for each one of them. Why do you want to do that though? You might as well just playback a geometry sequence of the final result and use that instead of deform.
edward
the reason is that im creating animation between maya dynamic, daz studio and ue4, hard to explain though.
Can I replicate sopcreateedit through pointvop?
edward
ruudygh
edward
Nevermind though. I used excel to generate hscript for this workflow purpose:
fcur 1
sopcreateedit -d diff1 sop1 sop2
fcur 2
sopcreateedit -d diff2 sop1 sop2
fcur 3
sopcreateedit -d diff3 sop1 sop2
fcur 4
sopcreateedit -d diff4 sop1 sop2
problem solved for now. thanks.
can you provide meshes for your problem? it's much easier to work with something than have to make some for the sake of an example
ruudygh
It's doable in theory but it's complicated because you need to use the Capture Attribute Unpack SOP and then basically redo what a Deform SOP would except invert the matrix that applies the deformation before multiplying it with the target position to compute the original position.
For the scripting, I would have just used python to do a loop … something like:
for frame in xrange(1,200):
    hou.setFrame(frame)
    hou.hscript("sopcreateedit -d diff%d sop1 sop2" % frame)
edward
ruudygh
    hou.setFrame(frame)
Sounds too complicated for a beginner like me. Will try it one day when I am expert
And thanks for the python script. Never thought that hscript can be mix with python.
