UV missing on alembic export
   18535   7   2
I have a mesh with two UV sets, UV1 and UV2.
I export it as alembic, then import the same alembic back into houdini.
The imported alembic now have same UV on both UV sets, means both sets are UV1, and UV2 is missing…
Could anyone help? thanks.
UV_missing.hip (2.0 MB)
Looks like a bug in Alembic. Just use .bgeo.sc file extension instead of .abc.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Enivob
Thanks for the response. Now im gonna google on how to import .bgeo.sc into maya
You might try exporting separate alembic files for each UV set, then consolidate them in Maya
Yes I'm having the same problem, using a new boolean sop and when I export alembic animation out of houdini into Maya theres some random uv's missing on frames of the animation, really crap. Anyone got any ideas?
Promote point attribute “uv” to vertex attribute. Just ran into this problem today. This fixed the export to alembic.
dennissedov
Promote point attribute "uv" to vertex attribute. Just ran into this problem today. This fixed the export to alembic.
that worked for me. Thanks!
I also encountered a similar problem.
In `rop_alembic -> Geometry -> Additional UV Attributes` add `uv*`.
This way all uv can be output to the abc file.
Edited by HenDaSheng - Nov. 24, 2022 06:40:40
