Hi All,
While the new H16 viewport has some nice features, I wish I could turn them off. I don't want those numbers or fog in the background.
Is there any way to turn these new options off?
H16 Turn Off Fog In Viewport Background?
4657 13 0-
- Enivob
- 2658 posts
- nisachar
- 83 posts
To remove the numbers on the viewport grids:
Right click the grid icon ( top right of the viewport ) and choose “no rulers.”
You also set the viewport color scheme by pressing D in the viewport and then choosing either Dark or grey as the color scheme. These schemes use a flat color. If you wish to further tweak the color settings then changing values ( top two lines ) in the “3DSceneColors.xx” file can help. You can open these files with any text editor.
Ideally, Sidefx should provide these tweaks via GUI
- Enivob
- 2658 posts
- malexander
- 5286 posts
- anon_user_89151269
- 1755 posts
- malexander
- 5286 posts
- nisachar
- 83 posts
- anon_user_37409885
- 4189 posts
- 1755 posts
- Enivob
- 2658 posts
The only reason I ask is that H16 completely crashes on my MacMINI, which is under spec. It crashes immediately when I try to navigate anywhere in the viewport. I assumed it was this new fading effect but it probably is more related to those new large ruler numbers.
Anyway, it does not matter. I know the MacMINI is not supported in any way. I just hate throwing away an i7 8 core processor when I really need more cores to do my work.
Using H15.5 I at least could dabble around in apprentice and try out things. With H16 I am completely shut down on the OSX Mac platform.
Edited by Enivob - Feb. 24, 2017 15:33:42
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- malexander
- 5286 posts
- Enivob
- 2658 posts
- malexander
- 5286 posts
- ralabate
- 7 posts
Just wanted to chip in – spent a few hours this morning trying to get H16 to run on a mid-2012 MacBook Air and @twod's tip to turn off numbers on the grid saved my bacon.
Before I did that, literally any mouse interaction would crash Houdini. Basically, consistent continually crashing just by clicking-and-dragging in the viewport.
