I have purchased Houdini Idie
1 Renderer (Non-Commercial) 16.0
1 Houdini FX (Non-Commercial) 16.0
1 Houdini Indie 16.0
When i install the product (No other Houdini versions installed)
Setup has by default like this:
Should i un-check the commercial License Server?
I did buyy Indie version (NODE LOCKED
ANNUAL RENTAL)
COst 199 USD
What for are those HQueue Client and Server?
Installing Houdini 16 (Indie)
3735 4 1-
- ISUther
- 116 posts
- malbrecht
- 806 posts
Moin, anonymous,
no, because “Indie” is a commercial license (which is clearly stated by the EULA, which you probably read).
Have you tried the docs?
http://www.sidefx.com/ja/docs/houdini/ref/hqueue [sidefx.com] (tldr: Render management).
As for your other issue (second thread): If you are on Windows, try running the License Tool as Administrator to install your licenses. If automatic installation does not work, try a manual installation, download a license file from http://license.sidefx.com/login.php, [license.sidefx.com] save it to your HD, open it, copy the content to your clipboard and paste that into the License Tool “Enter license manually” input field.
Marc
Marc
Good bye.
Good bye.
- ISUther
- 116 posts
http://license.sidefx.com/ [license.sidefx.com]
Requiers to log in.
There i use same username and password that i use to log in to Side FX (as i am posting here).
But it is not working.
And i did try also run as admin with Licence administrator.
Requiers to log in.
- malbrecht
- 806 posts
Have you tried resetting your password?
http://license.sidefx.com/reset_password.php [license.sidefx.com]
Obviously something with your login credentials isn't working.
Marc
Marc
Edited by malbrecht - March 5, 2017 14:33:53
Good bye.
Good bye.
- ISUther
- 116 posts
