python how to drop a for loop block
   2710   2   0
i am wondering now that we do for loops in houdini and drops 2 nodes, how can i do that with python, do they have a particular name?
thanks guys.
If you don't know something you can drag and drop it into the Python Shell and obtain it's path. From there you can also assign that path to a variable then use standard Python print dir(my_var) to determine properties and methods.
Don't look for the name, look for the type.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
This is the code for the For loop, for example.
import soptoolutils
import toolutils
(begin, end) = soptoolutils.buildBlockPair(kwargs, 'repeat', 'block_begin', 'block_end', False)
end.parm('itermethod').set('count')
