polygon sphere to "cage"
   2425   2   1
I have a polygon sphere and I try to remove its faces and then make two points poly in place of the old edges.
The polySpline sop doesn't work fine.
I am trying in wrangle but , in my actual wrangle, the 2points are doubled and I can't figure how to script to avoid that.
int myNeigh[] = neighbours(0,@ptnum);
int myPrims[] = pointprims(0,@ptnum);
foreach (int j; pointprims(0,@ptnum)){
    removeprim(0,j,0);
foreach (int i; myNeigh){
    int newPr =addprim(0,"polyline");
    addvertex(0,newPr,i);
    addvertex(0,newPr,@ptnum);
The code doesn't remember the last creations and then double it …
Any help is welcome
Vincent
http://vimeo.com/vbkstudio [vimeo.com]
When I do vex I just use my own defined ‘for’ loops.
Haven't used foreach yet, so I"m not quit sure what's going on in your code in that regard.
But just a thought, have you considered using the removepoint function? Your using the removeprim but that doesn't remove the points if that's what you were thinking.
Edited by BabaJ - March 13, 2017 19:55:06
Put the sphere in a “convertline”-node and you are done.
