Pyro Collision Issue
4663 3 1-
- gawrdun
- 2 posts
- Enivob
- 2658 posts
The main problem with your collision object is that you need to turn on polyextrude Output Back. This will cause “thickness” to exist within your collision object. Also inside the AutoDopNetwork visit the Static Object node and up the Divisions from 30 to 96. This will make sure your collision object is represented to the solver correctly.
Edited by Enivob - March 27, 2017 13:37:53
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- gawrdun
- 2 posts
Hey, thanks for the help!
I was playing around with the dissipation rate in the pyro solver to get a denser, thicker smoke. Something like this -
- reference image from Google
Is it possible to invert the dissipation, something where the smoke starts off thinner but ends off denser?
Also, is there a difference to Volume Based Collision Detection (Volume) and Bullet Data Concave?
Edited by gawrdun - March 27, 2017 22:31:10
- Enivob
- 2658 posts
