Playing around wit the new terrain tools.
I created a simple distorted heightfield terrain, where I scattered points on with the heightfield_scatter node.
From there I use a simple box and a copytopoints node to scatter boxes on the terrain.
Both are merged into one stream.
All this works in the viewport, but the boxes don't render in a region or the renderview.
The terrain and boxes will render when selected as the node itself.
Is there something I'm missing here, or does a merge not work in this case?
rob
terrain tools - scattered objects not rendering?
3934 2 1-
- RobW
- 147 posts
- dlee
- 476 posts
- RobW
- 147 posts
Hi dlee,
Yes that could work, but there are some things happening when doing that:
1. OpenGL view will now show -only- the base texture when using a ‘quickshade’ node for texturing the terrain, instead of all textures used in that node. It will render OK though, so this is a bit confusing.
2. There is a visible UV shift when comparing the heightfield render and converted terrain render.
3.When rendering the merged stream for the scattered objects, shading on the terrain is ignored, resulting in a very flat terrain render. Also the scattered objects have taken over the point color from what looks like the ‘erode’ node. Edit: Fixed this by moving the scattered points into a new geometry node via a object merge.
Maybe we need some additional ‘heightfield’ nodes? ;-)
thanks!
rob
3.
thanks!
rob
Edited by RobW - April 13, 2017 03:49:55
Apprentice Attribute / Houdini 17.0.381 / GTX 970 - driver 411.63
