Hey guys,
I am new to Houdini, and am very excited about its capabilities.
I am following the crowd simulation tutorial off pluralsight/Digital Tutors, but i have run into a problem when attempting to scale down the imported fbx character. The tutorial suggests that I simply connect a null at the top of the joint/bone hierarchy, (which is the hip null), set it to 0.1 and the character will scale down. However, the results that I am getting is just the hip null shrinking down. I should mention that the tutorial is from H15, and I am using H16, but i cannot imagine that something as basic as this has been somehow redirected.
Appreciate your help.
Scale FBX Character
4559 5 0-
- RoxyFilm
- 3 posts
- Enivob
- 2658 posts
Have you tried just using the Uniform Scale at the top level of the FBX subnet? Once you set the scale make sure to re-bake your agent clip.
There is also a Scale slider on the crowdsource node inside the crowdsource node for overall per-agent sizing. Geez SideFX two nodes named the same thing in different contexts? (you could have made this a little clearer).
Edited by Enivob - April 28, 2017 12:09:13
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
- edward
- 8083 posts
- edward
- 8083 posts
- RoxyFilm
- 3 posts
- edward
- 8083 posts
