Hey Forums! I am primarily a Cinema4D user in motion graphics. Years ago, a Houdini artist wrote a simple scene for me that would read an OBJ, then run it through a Sort SOP and save it out as another OBJ.
I remember the Sort node had options for what direction the vertices would be sorted. This is incredibly useful in motion graphics when I need to control the order of how polygons are constructed. Cinema 4D has no native tool like this.
I don't know the first thing about Houdini, so it's a really steep learning curve for me.
I'd like to ask a huge favor (and probably something very easy for you experts): Could you please write a scene like this for me to use?
If I recall correctly, it's a very simple 3-node scene (read>sort>write).
I'd be happy to donate some PayPal $ or Square Cash in your direction for such a helpful tool. (The company I'm currently working has Houdini 15 if there's a compatibility issue with scene projects.)
Re-sorting model vertices
3220 4 2-
- Dr_Pizza
- 2 posts
- neil_math_comp
- 1743 posts
The attached example has a File SOP to read in an OBJ file named “input_file.obj” in the directory containing the HIP file ($HIP). There's a Sort SOP that's currently set to do nothing, because I'm not sure what you'd like to sort points/primitives by. Then, there's an output ROP that you can press the Save to Disk button on to write to “output_file.obj” in the directory containing the HIP file.
You'll need to change the Sort SOP to sort points/primitives however you'd like them to be sorted. If you have any questions, feel free to ask. I'd hold off on paying someone to do something so simple.
- Dr_Pizza
- 2 posts
- neil_math_comp
- 1743 posts
Dr_PizzaNo problem. It apparently only took 79 seconds to create that file, so I figure it's worth it, haha.
Wow! Thank you so much for the lightning fast reply! I can't wait to try it out this morning!
- goldfarb
- 3467 posts
