How to quickly change topology?
5035 6 2-
- Jcreator
- 9 posts
- anon_user_37409885
- 4189 posts
- Jcreator
- 9 posts
Hi aRtye, thanks for your reply
The original mesh is a plain sphere, the processed mesh(topology-hive) was automatically generated by 3ds Max's topology tool.
The tool can apply a topology pattern over the entire surface of a mesh, as shown in this video ->
https://www.youtube.com/watch?v=b6KJOb-r16w&feature=youtu.be&t=1m55s [www.youtube.com]
Tool info-> https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMax/files/GUID-7358B7AB-86DB-4B3F-9954-BB11AA6FF3FE-htm.html [knowledge.autodesk.com]
I have no idea what tool or technique a proficient Houdini user usually use to change a mesh's topology to a certain pattern?
Recently I tried to make a Voronoi pattern by using Scatter + VoronoiFracture + Fuse, it seems to be okay…but I am not sure if there's any tool and trick I've been missing? I'm still quite new to Houdini, lots to learn
Edited by Jcreator - May 17, 2017 22:03:25
- edward
- 8081 posts
- Jcreator
- 9 posts
- 4189 posts
BTW Jake Rice has just published an amazing in-depth look at the Dual thingy:
https://medium.com/@jakerice_7202/computing-the-dual-ff2a93077e2e
- Jcreator
- 9 posts
aRtyeIt's amazing, thank you very much aRtye!
