Does anyone else have major display issues when using instance nodes? Across windows and Linux and every build of 16 so far I've had several minute long hangs after fitting the view when instances are being displayed. The CPU is pegged the entire time.
At this point I've had to turn point instance display off completely.
Display hangs with many instances in viewport
2664 2 0-
- Simon van de Lagemaat2
- 116 posts
- jsmack
- 8188 posts
- 116 posts
jsmack
I wouldn't try to display more than 5 or 6 at a time if the instance is heavy. Try setting the instance limit to 0, or lowering the percentage.
Ya the % almost never works properly. It's probably having to start another scene view tab or something but it gets stuck often.
This is all with bboxes btw.
Edited by Simon van de Lagemaat2 - Aug. 30, 2017 17:54:17
owner the Embassy VFX
