Houdini Indie Export to Alembic
3238 1 0-
- BradASchreiber
- 117 posts
- Enivob
- 2658 posts
If you middle click on the File node that brings in the Moon you will notice that there is no actual mesh geometry in your scene. What you are looking at in the viewport appears to be volumes. Alembic and FBX can not contain volume data, that is one reason why .bgeo.sc is so nice, it can contain volumes and attributes.
Drop down a Convert node after the File and connect them. Then middle click on the Convert and you will see that you have actual polygons.
Move the Display flag to the Convert node then try your export again.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
