Can't make character interact with flip ocean tank.
   2203   1   0
Hi all, I'm a new Houdini user still learning the basics but I want to make a test with ocean simulation interacting with a character that I modeled and animated in Blender.
I imported the character with animation as Alembic and when I select Ocean Flat Tank for the self menu and then click the character to connect them I have an error “ NoneType object is not iterable”. I think it's because the alembic file because if I create a cube for example it works. Is there a way to connect the character with ocean to have collisions?
Thanks in advance!
Ok guys I solved this, I applied a Surface Collider from the Solid shelf menu and worked just fine.
