How do you build a shader-based setup to project an image from one camera onto a surface and render through a different camera?
Appreciate any ideas!
Shader-based camera projections from a different camera
2575 2 0-
- jarjarshaq
- 65 posts
- Olaf Finkbeiner
- 323 posts
In the uv texture node you can choose the camera to project the uvs from.
That camera does not have to be the same as the one you render from….
http://www.sidefx.com/docs/houdini/nodes/sop/texture [www.sidefx.com]
Olaf
Olaf
- jarjarshaq
- 65 posts
