what is 16.5 equivalent of $NCY?
4797
4
1
bobc4d
Nov. 20, 2017 7:59 p.m.
I am following Rohan Dalvi's gear tutorial, he uses a copy node and then the expression 360/$NCY to rotate a circle. what is v16.5 equivalent of $NCY? or is there a node to do this?
Nov. 21, 2017 9:21 a.m.
You can use “copy stamp” sop and $NCY will work fine. It doesn't work with “copy and transform” sop
jsmack
Nov. 21, 2017 11:35 a.m.
you can channel reference the ncy parameter instead. $NCY is a static value that simply refers to the number of copies. ch(“ncy”)
bobc4d
Nov. 21, 2017 7:10 p.m.
thank you very much for the responses. the copy stamp node worked like a charm.
zuleikaf
March 18, 2018 4:33 p.m.
This guy Rohan is great. I was also stuck on this thanks.
