How can I use ramp node itself, not the parent parameter settings?
Whenever I place a ramp node it seems to be taken over by the parameters added to the parent. I would like to simply use the ramp node wherever it is, using the gradient on the node itself rather than the parent. Tried the “use this node to set parameter attributes” checkbox (not sure if this is related) but it didn't answer my need.
Ramp Node Parameter Settings
2044 7 0-
- monomind
- 22 posts
- Nima
- 471 posts
Hi.
Yes you can solve this problem.
First select your ramp node and then press Shift + C to create subnet from selection.
Then go to that level where you see ramp and from gear icon at the top right of parameter editor panel select Edit Parameter Interface.
Find the ramp in Existing Parameters section and then select that.
From Parameter Description set the Scope option to Subnet Connector and finally accept changes.
Hope this helps.
Hope this helps.
- monomind
- 22 posts
- monomind
- 22 posts
- Nima
- 471 posts
- monomind
- 22 posts
- Nima
- 471 posts
- monomind
- 22 posts
