VEX: How do I append a list of attribute into an array prim attribute
   16588   4   2
I have list of objects have primitive attribute : instance (Image : Highlighted in Yellow)
how could I append the instance attribute by unique value into an array prim attribute ? (Image : In green text)
Thanks a lot
Edited by cgmagic.sunhe - Dec. 10, 2017 17:37:59
Is this what your looking for?
Put the following in a wrangle for primitives run over.
You say you want to append, which is why what I wrote takes the existing instance value puts it as the first value of the corresponding new primitive array attribute.
i[]@Instance_Array;
int Transfered_Instance;
Transfered_Instance = prim(geoself(), "instance", @primnum) ;
push(@Instance_Array, Transfered_Instance);
push(@Instance_Array, 1);
push(@Instance_Array, 2);
Sorry, maybe I could explain better. I am looking for
// Get each @instance from each prim.
// Make a new array attribute for each prim called @instance_array.
// only push each @instance from prim into the new @instance_array, if the item is not already in the list. For example, if there are more than one @instance==1, only push one of them into the array.in the array you won't have the same value twice.
since the array will be the same, there is no need to store it on each primitive
so I suggest running this in Detail mode
however if you want you can over Primitives
int n = nuniqueval(0, "primitive", "instance");
for (int i=0; i<n; i++){
    int inst = uniqueval(0, "primitive", "instance", i);
    append(i[]@instarray, inst);
Thanks for this post Tomas.
I wasn't aware of the functions nuniqueval/uniqueval.
Definitely reduces the amount of code to do the task otherwise.
