Change points / particle size?
   10727   4   2
Hey everyone
This is my first time in Houdini and i can't seem to find where you change the point /particle size?
The size in the viewport is around where i want it but the real size in the render is huge.
Does anyone know how to change the point size ?
Best regards
Susanne
susDissolve.hipnc (447.6 KB)
in a attribute wrangle use @pscale.
Mantra uses the pscaleattribute for the radius of points; I think it defaults to 0.1 if there's no attribute present. It looks like if you put @pscale = 0.004;in an Attribute Wrangle, (or you can use Attribute Create, if you'd rather avoid VEX), that's a somewhat reasonable value. Hopefully you can play around with it and find some value you like.
I threw in a point wrangle in your file for controlling pscale.
Pscale.hipnc (573.0 KB)
Thank you guys for the response. Was not expecting a reply to fast.
It works now!
BabaJ
BabaJ
@nDickson
nDickson
nDickson
@sepu
sepu
sepu
Is this how you tag people in here?
Edited by susanneBloch - Jan. 16, 2018 06:10:01
