Copy to line segments
2246 3 1-
- PolygonPig
- 2 posts
Hello, I'm new to Houdini and had trouble figuring out the correct way to do this. I created an attribute wrangle that takes a line and drapes it in an arc. I was wondering how I could copy my draped line to each line segment of the input_crv? I attached a scene to look at. Thanks!
Attachment Not Found
- neil_math_comp
- 1743 posts
Try the Sweep SOP. It copies geometry to each point in a curve, with a transform based on the curve. It may require some fiddling to override the transform (possibly even with
Nor upattributes on the points) if the default is not the transform you want.
- Werner Ziemerink
- 1269 posts
- vusta
- 555 posts
