I'd like to loop the Time period of the Mountain sop instead of doing it with the Offset value, can this be done please?
A.
Any simple way to loop the Mountain SOP please?
3593 3 0-
- Adriano
- 411 posts
- Adriano
- 411 posts
- jsmack
- 8177 posts
- Adriano
- 411 posts
You beat me to it, was going to thank my empty thread for being such a good rubber duck
as i just discovered the blendshape while browsing the interweb, and consequently used that method, animating the Y offset and bringing the second mountain to the same offset translation at the end of the blend. But believe it or not my first go to move was trying to recreate the blend shape myself not knowing it existed, using some get attribute P into an attribute SOP and mixing between inputs :$ …silly me, reinventing the wheel. I really need to go through the entire list of the SOPs of the manual, eh.
Thanks again!
as i just discovered the blendshape while browsing the interweb, and consequently used that method, animating the Y offset and bringing the second mountain to the same offset translation at the end of the blend. But believe it or not my first go to move was trying to recreate the blend shape myself not knowing it existed, using some get attribute P into an attribute SOP and mixing between inputs :$ …silly me, reinventing the wheel. I really need to go through the entire list of the SOPs of the manual, eh. Thanks again!
