Always selecting top edges/points
   2609   2   0
Hey!
I am currently working on a tool that will generate cliffs. So far I have made the base wall of the cliff but now I want to be able to select the top edges of it so I can extrude the edge to make a sort of terrace.
I want to be able to always select the top edges of the cliff even if the height of the cliff is sloped or have a height different.
How would I do this?
while not answering your question DIRECTLY, if I'm faced with this problem, here's how I would get ‘around’ the problem..
vu_extrude_top_only.hipnc (67.5 KB)
Group SOP
Keep By Normals: Enable
Direction: 0,1,0
Spread Angle: tweak to whatever you need
then extrude just that group
