Hi there.
How I can change the particle size in the Pop Network ? I cant change it at geometry level as I have a combine node where I already compile my sources using an Object Merge so that will affetc all my particles and I want to affect only one source. The only way I can think to change the particle size is at the Pop Net level.
Is this possible ? Any ideas ?
Cheers !
Particle Size
5992 4 1-
- Imconected
- 20 posts
- Enivob
- 2658 posts
- Imconected
- 20 posts
- Imconected
- 20 posts
- Enivob
- 2658 posts
That is just a warning that you have unbalanced the attribute merge by adding another attribute to that particular input stream. You could add a wrangle to each input and set the @pscale to 0.0 on the others and then the warning should go away.
Edited by Enivob - March 17, 2018 12:51:57
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
