Glue Constraint Connections are wrong - HELP!
   2492   2   0
I'm trying to do a simple fracture of a model in preparation for adding smoke/dust emission upon shattering. I want to use glue constraints to hold some of the pieces together.
I used a For-Each Loop to subfracture some of the pieces.
But once I add the Glue Constraint network, the constraints all converge at the centroid of the model I'm using, instead of to the adjacent pieces.
Any ideas on how to fix this?
BTW the model can be downloaded from here… [threedscans.com]
Attachment Not Found
Edited by Grayson Mendenhall - April 3, 2018 14:17:44
abstract_shatter.hipnc (699.1 KB)
hi,
you must set “adjacent pieces from points”.
Is that what you meant?
That worked to an extent, but I think I may need to rebuild the set-up to figure out what I did wrong.
