Baked maps too dark - Unlit Diffuse Color
2375
4
1
April 7, 2018 7:53 p.m.
I am baking unlit diffuse maps from high poly to low poly with the baketexture ROP to MPlay. The results are too darkas you can see in the images below. I already did:
Turn-off head light creation Switch texture color space in principled shader Set MPlay to Gamma 2.2 Tried JPGs and PNGs as input texture Is there anything left to do?
jsmack
April 7, 2018 9:05 p.m.
Does the principled shader still have a base color of 0.2?
April 8, 2018 2:44 a.m.
Thank you, jsmack! That solved my problem. I was thinking the map overrides the base color
April 8, 2018 3:18 a.m.
BTW: Whats the most minimal approach to get texture baking working from a materialbuilder? I tried uvcoords -> texture -> pbr-diffuse -> surface_output and also bindexport: Cd But it didnt show up in the baking.
jsmack
April 8, 2018 11:51 p.m.
surface exports has all the baking stuff, but you have to add the expected exports to the input layer struct.
