Control rotation of each primitive & normals clone ?
2791
2
1
April 11, 2018 11:50 a.m.
I have a question, if each primitive is separated from the other; how would you rotate primitives independently based on a vector attribute ?
Also;
How do you create a second set of normals based on an attribute which behave identical to that of the normals attribute ? How do you create a vector that follows an edge ?
【T】【C】【S】
BabaJ
April 11, 2018 1:19 p.m.
Everything your attempting to do is covered in this tutorial, study it thoroughly:
http://www.entagma.com/td-fundamentals-parallel-transport/ [
www.entagma.com ]
If you have problems with the tut in applying it to your specific application, just make a small hip file with focus on the issue and someone might be able to help.
jsmack
April 11, 2018 2:19 p.m.
Use the group field of the transform sop. Will transform just the primitives in the group.
