VEX: store @P from frame one
   2175   2   1
Hi!
I'm using @P to scatter some shapes on a dress. When I play the animation, some funky stuff happens because the @P changed over time.
How can I “store” the @P found at frame one and never change it after?
Thanks.
-Olivier
Branch the source node with a timewarp node set to desired frame you want to “catch/freeze” the values at.
Then in the other branch use a vex function like the pointattrib() function to bring in the values from that timewarp node.
Edited by BabaJ - May 19, 2018 21:23:49
Ahhh!!
Sounds way more efficient than what I was trying…
Thanks BabaJ!
-Olivier
