Hi everyone.
I am rather new to Houdini but managed to build a working FEM simulation and to write it out as alembic to render it in c4dtoa. However I am striggling to get a proper motion blur. After some researching I found out that I need to write the velocity attribute to the alembic so arnold can read it.
I guess the trail node creates the velocity attribute, but how do I tell the alembic rop node to write it out?
Any help is appreciated!
Thank you!
how to wirte out velocity attribute to alembic?
10895 13 1-
- lurklurkson
- 16 posts
- jsmack
- 8177 posts
- lurklurkson
- 16 posts
- Tanto
- 542 posts
Hey, maybe this thread could help you:
https://www.sidefx.com/forum/topic/44006/?page=1#post-197149 [www.sidefx.com]
- lurklurkson
- 16 posts
jsmackHey, in my case it doesnt somewhow.
The alembic rop outputs all attributes by default. Unless you have specifically disabled the attribute, velocity should exist in the export.
I have a dopimport node that fetches the geometry. This node has the v Attribute. However when I plug it into an alembic rop, export it and reimport it, its not there…
- Tanto
- 542 posts
- lurklurkson
- 16 posts
- Tanto
- 542 posts
- lurklurkson
- 16 posts
- Tanto
- 542 posts
- lurklurkson
- 16 posts
- lurklurkson
- 16 posts
- Tanto
- 542 posts
- Achilles3000
- 2 posts
Hey there, iam struggling with the same Problem. But Redshift.
Alembic file written out with velocity via trail. Checked all steps. In Geo Spreadhsheet also iam on the good side.
Inside C4d still no Redshift Motionblur working, besides a simple sphere made inside C4d works great next to the .abc file.
Would be happy about any advices.
