Any way to pick Object Merge objects from viewport?
2089 5 1-
- Tanto
- 542 posts
- Olaf Finkbeiner
- 323 posts
- Tanto
- 542 posts
I am, but how does that help?
I'll often be loading Alembic files with complex hierachies. Selecting the objects I want in the viewport would be trivial, since the organization makes sense in 3D space, but Object Merge from selection doesn't seem to exist. Picking them from the floating operator chooser or using paths and wildcards is a pain.
- Olaf Finkbeiner
- 323 posts
- jsmack
- 8177 posts
You can try the ‘Extract’ tool from the scene view. Select the primitives you want to merge into another object, and hit tab->Extract. The tool creates a new object containing an object merge, instead of letting you pick an existing object to merge into, but at least you can cut and paste the object merge where you want it.
- Tanto
- 542 posts
@Olaf: Thanks, that would work, but I'd have to merge everything into a single object beforehand.
@jsmack: That's great! It creates one Object Merge node per object instead of a single one, but I can live with that. Thanks!
Edit: @Olaf: …although it would work with bundles… Haven't used them much but it would be perfect for this, I guess.
Edited by Tanto - June 1, 2018 14:08:35
