Objects do not appear in 3ds Max
   5562   5   0
Hi there I am following along with this tutorial [www.youtube.com] but when I try to load the hda file in 3ds max nothing happens. I select the hda file directory and press load but nothing seems to be happening. Any advice?
I have the object condensed into a subnet and believe I've followed the steps exactly
Which version of Houdini 17 are you using? Apprentice/Indie/Core/FX?
Also: check the “Session” tab to make sure that a Houdini session is currently active.
Edited by BrookeA - Oct. 15, 2018 17:33:47
Thanks for your reply. Im using the latest version of apprentice available on the sidefx website. I had double checked the session tab and it said that the session had started. Im using 3ds max 2018 if thats relevant
Edited by Stu22 - Oct. 16, 2018 03:54:34
Unfortunately, Houdini Engine is not available in Apprentice. It's failing to load the assets because it is failing the license check.
….ah…. i see….
Thanks for your help though!
I had the same experience. It is too bad, it would a good way to attract new users as it exactly shows the power of houdini compared to 3d max.
