Groupexpression with strings
   2512   3   0
hey guys,
can somebody please enlighten me?
i don't understand how to deal with the groupexpression node and string-attributes.
I'm playing around with the osm-importer of the gameDevToolset
the incoming data have tons of primitive attributes, i want to use to create groups.
in the groupexpression node (set to primitives) i type the following:
@P.x > 50 —> works, although there is no primitive attribute “P”
@addr_postcode > 1000 —> gives no error, but an empty group, although there are prims with this attribute > 1000
then i realized, that all attributes in the osm geometry are strings, so i tried
atoi(@addr_postcode) > 1000 —> throws a no matching function error
@addr_postcode == ‘10004’ —> throws an undefined binary operator error
can somebody explain how to test for specific strings and how to
convert them to integer/float for testing against numbers
in a groupexpression node?
Thx in advance
@addr_postcode == “10004”
if i rememder right
Although not listed all primitives inherently have their ‘centroid’ value accessable with @P
Adding s to your attribute will work;
s@addr_postcode > 1000
Anytime you wish to access user defined attributes outside of the wrangle/node in which they were created you have to let Houdini know their type with a prefix, otherwise it will create a new one with the same name but with a default type and value.
Thank you guys for your thoughts on this,
The solution was a combination of both of your approaches:
when searching for a specific string:
s@addr_postcode == “10004”
When testing against an integer:
atoi(s@addr_postcode) > 1000
Thank you very much!
