Missing Tutorial - Create Terrains From Elevation Maps In Houdini
   3746   3   1
Hi
I'm new to Houdini and Terrains but there have been some great tutorials under ‘Learn’. One was posted on there some days back called ‘Create Terrains From Elevation Maps In Houdini’. I watched it once, and it was really interesting but it's no longer up there, and the link does not work any more:
https://www.sidefx.com/tutorials/create-terrains-form-elevation-maps-in-houdini/ [www.sidefx.com]
(note type ‘form’ not ‘from’ - but neither works)
Im trying to get from real world satellite data to a terrain, and this tutorial showed the process step by step.
Is this tutorial (or an alternative) still available please?
Thank you!
it's here:
https://www.sidefx.com/tutorials/create-terrains-from-elevation-maps/ [www.sidefx.com]
Training Lead
www.sidefx.com
I followed the steps in that tutorial and wasn't able to see any results.. Am I missing something? I reread and double checked several times.
Many thanks!! I found it again. I worked through as it worked like a charm.
@rgbxyz - I didn't see anything until the final step where there was a calculation to set the displacement distance, but it does all work. Did you try picking a region with very obvious terrain changes - eg mountain range?
