Crowds - Agent Unpack to fix Normals, and Repack/Assemble?
   5910   9   1
Hi all, the FBX export/import of my character seems to muck up the normals. Is there a way wrangle/unpack/etc to fix these and reassemble the agent?
I can dive into the imported FBX object and add a Normal node, but this could be an issue if changes are made to the FBX and it needs to be reimported. I'd have to do that every time to every FBX that's brought in, bleh!
If you think I'm missing something in the Maya FBX export that would fix the normals, please let me know!
Couldn't you use setprimitinstrinc on the normal?
http://www.sidefx.com/docs/houdini/vex/functions/setprimintrinsic.html [www.sidefx.com]
You could unpack the original, set the normal then set the intrinsic attribute from the derived new normal.
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Thank you, Enviob! I feel like this is the right idea.
I'm uncertain how to proceed in the wrangle since I can't find an intrinsic “normal” or “n” attribute.
What I have so far isn't breaking, but it isn't fixing the normals either.
int totalPrims = nprimitives(1);
int nPrim=0;
for nPrim<totalPrims{
//setprimintrinsic(int geohandle, string name, int prim_num, <type>value, string mode="set")
setprimintrinsic(0,"n",nPrim, "60", "set")
nPrim+=1;
Edited by Totheroo1 - Oct. 26, 2018 12:32:59
I think you have the attribute named wrong, use capital “N”.
Try this in your primitive wrangle.
int success = 0;
for (int nPrim=0; nPrim++; nPrim<totalPrims){
    // Fetch normal from input 1.
    vector tempN = primattrib(1,"N",nPrim,success);
    if (success==1){
       // sucessful fetch of data, time to assign.
       setprimintrinsic(0,"N",nPrim, tempN, "set");
Edited by Enivob - Oct. 29, 2018 09:46:19
Hi, I'm having the same problem, but the
does not work on my agent.
Anything I can do?
Edited by scorpes - Nov. 22, 2019 08:30:44
I would like to add a rest position as well, with setprimintrinsic, I cannot get it to work, any help would be appreciated.
I have tried the above mentioned method without success.
Was anyone able to make it work or have found a different solution?
also having this same issue with none of the above working, anyone ever get a fix?
you have to clean it up first place in maya
These days it would be simplest to use the FBX Character Import SOP to import into KineFX, clean up the skin geometry as needed, and then assemble the agent using the Agent from Rig SOP, Agent Layer SOP, etc. This avoids the extra step of importing to an agent and then trying to unpack and repack it
