Points from VDB volume
   2195   1   1
I am a little confused by the results from the “Points from Volume” SOP. (h16.5 on windows 10.)
See attached example, I create some example geometry t work with.
I then create a VDB volume. I set the voxel size to 0.25, and I set the Exterior Band Voxels to 2.
I try two approaches:
  • In one I create a signed distance field.
  • In the other, I create an unsigned distance field.
I then use the Points from Volume SOP to generate a grid of points that are close to the geometry surface, with a tolerance of 0.2.
Neither seems to produce the right result. The unsigned field produces nothing, and the signed field produces some points, but many points are also missing.
I guess I must be doing something wrong…
points_from_volume.hipnc (139.1 KB)
Patrick
I also tested this on h17, with same results. Any ideas what I might be doing wrong?
Patrick
