different FPS between 3DS Max and Houdini engine ?
   5055   1   0
hi
playing around with Houdini engine in Max
the integration works very well so far
but i notice a Timing problem
for example:
if I set the animation length in my Asset to 100 the animation ends at 82
if I set the frame Rate in MAX to 30fps the animation ends at 99
so is there a Timing problem ?
Thank you for reporting this. I've logged a bug and will investigate.
