Flipbook and Scene View visualization are different (Solved)
3445 6 1-
- RiccardoT
- 39 posts
- fastbom
- 1 posts
- RiccardoT
- 39 posts
- tamte
- 9380 posts
in flipbook or viewport you can enable Color Correction bar where you can set your desired color correction settings
however to set your defaults go to Edit/Color Settings/Color Correction and make sure both Viewport and Flipbook use the same settings, overall you may want everything to have gamma or LUT applied, but ultimately its up to your workflow
- RiccardoT
- 39 posts
- RiccardoT
- 39 posts
- Wren
- 532 posts
, what can i do to solve this?
