How to export separate Mesh model by FBX
   6279   4   1
Hi every one,Do you know the way to export Group mesh ??
i really don't know how to export 2 group of mesh with FBX export on the same file.
Because If it can work , I will add layer mesh group on Unity.
Or if you guys have another idea to add more layer on one file on Unity or Houdini , Pls help me !!
Thank you so much!!!
** my point is can select mesh layer on that file.!!!****
Hello ,
One Solution is to have them as separate Object in Houdini
You can split the part and use object merge at the end if you want to work in Sop !
Hi Benjamin Lemoine , or everyone !!
But i create my asset form lot of node , like try to make it like procedural-modules
just right now i really don't know when i will use in unity how to add layer ground and wall together on same file.
Thank you a lot !!!
Hello , you can use some group , and at the end split some part and Object merge in another geo if you want it on another object !?
Also, if you export as Wavefront .obj files that will respect SOP groups. For me, that is a lot easier than dealing with breaking apart all my models at the Houdini /obj level.
