Does GPU with double precision helps with simulation?
4003 7 3-
- ouroboros1221
- 79 posts
I noticed most consumer GPU barely hit 1 teraflop mark in terms of double precision. In houdini simulation, there are solvers that use double precision, such as flip solver(FP32 is also an option). Would such GPU accelerates computations with openCL? If a computer system not only has one GPU, but it also as an accelerator such as Intel Phi, or Tesla V,etc. Would that be utilized when openCL is turned on in Houdini?
- brokenkeyframe
- 57 posts
- anon_user_37409885
- 4189 posts
Interesting question, my take on it is the acceleration will only affect error reduction in the sim and the 64bit option appears to be only in the viscosity section of the Flip solver. When using 32bit it still uses a 64bit buffer to help stop the accumulation of errors. On a quick test there is a 5% speed difference using 64bit vs 32bit with high viscosity on a 1080ti/Linux. You can run a test today to see if the visual difference is worth that, less noise is all I've noticed. Note the further the sim is away from world-space 0 will introduce more noise too.
A Quadro card's advantage might be the apparently faster PICe channel back to the CPU, larger Vram and 10bit colour support.
Only one OpenCL device is support ‘at the moment’, which has been true since 2011/12…
Hope that helps.
Hope that helps.
- ouroboros1221
- 79 posts
very nice of you to put the flip solver into test fuos, if only I had a Quadro GV100 of that sort, I'd definitely also test out FEM solver which utilizes 64bit precision as well. The “only one openCL device is supported” was also an interesting insight, what if I have a 1080TI along with a NVIDIA T4(accelerator), how does it know which one to use as the openCL device? (I reckon it'll use whichever is occupying the first PCIE lane, cause it'll have a device ID of 0)
Edited by ouroboros1221 - Jan. 17, 2019 18:33:22
- 4189 posts
No worries, this area is a hobby of mine
FEM only uses a C++ path at the moment, so the only hope is that it takes advantage of AVX-512. H17 has initial support though the release notes lacks granularity. There is literature that suggests this instruction needs to properly implemented to be more than non-useful:
https://lemire.me/blog/2018/04/19/by-how-much-does-avx-512-slow-down-your-cpu-a-first-experiment/ [lemire.me]
OCL device choice is very easy now, decided via the Preferences/miscellaneous.
EDIT: the ChangeLog suggests it's only VEX support for AVX-512, so the FEM solver most likely doesn't use it.
Edited by anon_user_37409885 - Jan. 17, 2019 19:04:34
- ouroboros1221
- 79 posts
- 4189 posts
that would require a @jeffLait quality answer
My lay persons understanding is that you are computing 8 x 64bit vectors in one hit, with a multiple and add, so if your data can't fill those registers you are not efficiently using that cpu cycle. In essence my theory is it's a too large a buffer to fill with non-contiguous data… now over to someone to who knows actually what is going on.
- lorsange
- 9 posts
- Open houdini.env (C:\Users\"user"\Documents\houdini xx.x) using a text editor.
- At the end add the following line (HOUDINI_OCL_DEVICENUMBER = 1)
In some cases you need to add the following line (HOUDINI_OCL_VENDOR=“NVIDIA Corporation”) for Houdini to pick up the specified gpu.
The numbering system starts with 0 (the main gpu) and then 1 (you second one).
Save the file and open Houdini, go to Help menu > About Houdini > Show details, then scroll down to check Opengl it should show your main GPU, go down more and you will find Opencl is assigned to the second one.
