how to create one polygon from connected lines?
   8310   2   0
Hi!
I've made a shape with 4 polylines. I've fused the 4 corners and I would like it to be a polygon instead of a polyline. I tried polyfill sop but it looks like it's causing problems with my boolean later on. What would be the best way to close this shape?
Thanks.
-Olivier
Try polypath with ‘Make isolated loops closed’ enabled. you can also skip the fuse if you enable ‘connect end points’.
Nice!
Thanks.
-Olivier
