Rivets
   4199   7   1
Hey guys,
I'm trying to model a lamp-post to then attach to then copy to a number of points on a spline. Ideally I want to have a light attached to the geometry rather than hand placing lights.
I've read here that a rivet could perform the job - https://www.sidefx.com/forum/topic/16450/?page=1#post-77817 [www.sidefx.com]
I am struggling though to get it working properly, could anyone help me diagnose why? I've attached two images to show my process.
What are the error messages? Do you have the up and N attributes on your point?
I think you need at least 3 points for a rivet. Have you tried sticky?
Sean Lewkiw
Machine FX - Cinesite MTL
mrCatfish
It will still work as a position constraint with one or two points, but you won't have orientation unless you have the x and z axis attributes on your point(s) (usually N and up).
Thanks for the replies guys.
Tanto
These are my error messages -
Error
Invalid point group top_point.
Error
No points available to attach the rivet object to.
Error
Error cooking transform of /obj/rivet1 (as child to world)
The top_point group is within my Geometry node but I cant really access rivets within the geo node so I'm not sure why it isnt being picked up
mrCatfish
Do you know how i can apply the different axis onto my point?
I get this error when i try sticky -
Error
Error cooking transform of /obj/lamp_post (as local)
Tanto
mrCatfish
Based on my error message above it sounds as though your right here, but my light is stuck to the ground before I'm even worrying about any orientation. Is there a way to add the Y axis to the operation?
Can you post your hip file? If the group is not accessible from the dropdown in the rivet node, then it either isn't a point group or it just doesn't exist. Can you access the group via the drop-down or are you typing it in manually?
Sean Lewkiw
Sure I'll upload it, I selected the group from the drop-down.
Rivet Troubleshoot.hipnc (986.9 KB)
Just toggle off “Use Point Vector Attributes for Rivet.” You don't have an up vector so it's failing. Since you are riveting a light, I assume you're not concerned about its exact orientation.
Also, put the full path to the group node: /obj/lamp_post/target_point. If you just put /obj/lamp_post it will point to whatever geo is displayed.. meaning that if you display geo before the group SOP, it will fail.
Edited by mrCatfish - Feb. 15, 2019 09:42:23
Sean Lewkiw
