nearpoint: don't pick currently processed point?
   2776   2   0
Hi!
I've got a point cloud and for each pt, I want to find the distance of the nearest pt. I was using the nearpoint function but I found out it always found the currently processed point to be the closest point.
What would be a simple way to exclude the processed point from the nearpoint search?
-Olivier
Use the return array of the nearpoints function and limit its' search to 2 pts.
Then always reference the second element of the array.(as the first element will be the point you are using to search from).
Edited by BabaJ - Feb. 20, 2019 11:07:30
yeah! I just found out.
-Olivier
