Preferences window too big to save changes
3525 3 2-
- DevoStevo
- 35 posts
I just installed 17.5 & but when I open my Edit>Preferences window, the bottom of the window is off my screen so I can't click on the Apply button to save changes because it is out of site. I can't drag or resize the window to fix it. Ironically I'm trying to reduce the size of my UI. I had this problem with Houdini 17 as well. Any chance of making the Edit>Preferences window a bit smaller so I don't have to post about it every time I get an update. I guess I could modify the Houdini.env to make UI smaller but really shouldn't have to do that just so I can hit “Apply” to reduce my UI size in settings in the first place.
Edited by DevoStevo - March 15, 2019 18:28:44
The only devil I know is in the detail.
- DevoStevo
- 35 posts
So I reduced the UI size in the Houdini.env txt file (HOUDINI_UISCALE = 90)so now I can hit apply to reduce my UI scale to 0.9, then I reverted the Houdini.env file to original & now the “Apply” button is just in reach.
That's a lot of hassle just to click a button.
It would be really good if you could just resize the Edit>Preferences window.
Edited by DevoStevo - March 15, 2019 18:27:36
- ajz3d
- 654 posts
- DevoStevo
- 35 posts
