After i “successful” cook my asset output is empty, but in HEU_PDG Asset Link seems like all ok. I'm even try files from tutorial, it's doesn't work too.
Tutorial already outdated or i'm doing something wrong?
Unity: 2018.3.8f1 Houdini: 17.5.173
Edited by Mstislav Pavlov - March 29, 2019 07:18:07
So it did generate the HEU_GeoSync object, with a valid file path it looks like. What do you see when you open that generated bgeo in Houdini? That bgeo must be a supported polygonal geometry for it to work in Unity.
Could you also try with moving it to C:\ instead of F:\ if F is mounted?
If you can, please attach the bgeo here so I can test it out.
The bgeo file loads for me (a cube) if I create a gameobject and attach HEU_GeoSync component, and specify the path to the bgeo. Can you try the same method?
Could be. Does the bgeo work for you in Houdini? Create a file SOP node, and specify the same path. It should load the cube. You can also try creating a simple HDA with a box sop inside and check if it loads in Unity via the Houdini Engine plugin.
Which Houdini license are you using? Also, please try with a newer Houdini daily build.
