Sweep corners wrong thickness SOLVED
   2259   3   1
Hi!
I'm using a sweep on a line and the corners are not thick enough. I tried scaling the corner points normals but it doesn't affect the Sweep. How can I correct this?
-Olivier
Edited by olivierth - April 1, 2019 16:09:16
Try extruding along normals instead of sweeping?
In my case, that would not work. I'm using a specific profile that can't be changed with an extrude.
-Olivier
SOLVED!
Doh! I simply needed to tick the Angle Fix option on the Sweep sop.
