ROP Fetch libHoudiniUT.so undefined symbol
   2562   0   1
Hi all,
In the latest daily builds for Houdini 17.5.208 and 17.5.214, it seems that all ROP Fetches appear to fail. It seems to be an undefined symbol in libHoudiniUT.so.
Just wondering if anyone else was experiencing this?
Dirtying and cooking the node immediately changes them to success and goes green.
It works successfully in 17.5.173.
All done on the local scheduler.
/home/142738/packages/houdini/17.5.214/install/bin/../dsolib/libHoudiniUT.so: undefined symbol: _ZN3tbb19task_scheduler_init27internal_blocking_terminateEb
Thanks,
Ben
Full output.
Houdini DSO error on '/mnt/ala/software/int_packages/usd_houdini_hdk/0.0.4/houdini-17.5.208+/embree_lib/dso/libOP_gusd.so'
	libHoudiniAPPS3.so: cannot open shared object file: No such file or directory
[SG update_context_variables] Ignoring update context variables, hdefereval not defined, most likely you are running a job in the farm and this automation is not needed.
Loading .hip file /mnt/ala/mav/2019/sandbox/users/benjamin.skinner/houdini/auto_lod/auto_lod_main.hipnc.
[Turret] Turret will not cache resolves to disk
TURRET USD Resolver - Created Resolver
[Turret] TURRET USD Resolver - using default resolver for file path: /mnt/ala/mav/2019/sandbox/users/benjamin.skinner/houdini/auto_lod/geo/pizzaBox01_LOD7_wip.usd
[Turret] TURRET USD Resolver - using ala usd resolver for file path: tanks119/publish_asset_variant_set_usd?Step=model&Task=model&asset_type=setPiece&version=latest&Asset=pizzaBox01
[Turret] usd resolver received live response: /mnt/ala/mav/2019/jobs/s119/assets/setPiece/pizzaBox01/model/model/caches/usd/v004/pizzaBox01_model_model_usd.v004.usd for query: tanks119/publish_asset_variant_set_usd?Step=model&Task=model&asset_type=setPiece&version=latest&Asset=pizzaBox01
[Turret] TURRET USD Resolver - using default resolver for file path: /mnt/ala/mav/2019/jobs/s119/assets/setPiece/pizzaBox01/model/model/caches/usd/v004/LOD0/pizzaBox01_model_model_LOD0_usd.v004.usd
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdSkel/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdLux/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdUI/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdVol/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/houdini/dso/usd_plugins/usdMantra/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/houdini/dso/usd_plugins/usdHoudini/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdShade/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usd/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdGeom/resources/generatedSchema.usda
[Turret] TURRET USD Resolver - using default resolver for file path: /home/142738/packages/houdini/17.5.214/install/dsolib/usd_plugins/usdRi/resources/generatedSchema.usda
PDG_RESULT: perform_lod_1_136;-1;'__PDG_DIR__/geo/pizzaBox01_LOD7_wip.usd';;0
/home/142738/packages/houdini/17.5.214/install/bin/hython-bin: symbol lookup error: /home/142738/packages/houdini/17.5.214/install/bin/../dsolib/libHoudiniUT.so: undefined symbol: _ZN3tbb19task_scheduler_init27internal_blocking_terminateEb
