Reloading Asset Definition frequently results in a 3ds max crash
6213 6 1-
- eikonoklastes
- 447 posts
Hi, I'm running Houdini Indie 17.5.173 and Houdini Engine v3.2 API 40, and while building a simple asset, trying to reload it in 3ds max, will almost always cause it to crash. Any thoughts on how to mitigate this? I'll submit a bug report on this as well.
Edited by eikonoklastes - April 18, 2019 05:36:42
- eikonoklastes
- 447 posts
Update: this isn't restricted to reloading the asset. It seems that any time I make changes to the asset in Houdini, while it is still loaded in max causes the whole thing to become unstable. Trying to then do anything with the asset in 3ds max, including trying to delete it, stopping the session, reloading it, causes a crash.
- BrookeA
- 391 posts
- eikonoklastes
- 447 posts
Hi Brandon. Apologies, things got a bit manic with work. The issue I face isn't restricted to any specific HDA. I have used about 3 or 4 different HDAs and I experience the same level of instability with all of them.
Could this be in any way related to the version of max I am using? I am on 2019 (21.0.0.845). Perhaps an update is in order.
- BrookeA
- 391 posts
- eikonoklastes
- 447 posts
BrandonASounds great, thank you. Looking forward to it.
Hi, no problem!
I think your 3dsmax version should be okay. I have an update coming soon that should increase general stability – including asset definition reloading. I will let you know once the update has been added to 17.5. Hopefully it will solve some of these issues that you are having.
- BrookeA
- 391 posts
