How to unwrap (linearize) render depenedancy tree?
   2441   3   0
(See attached image for demo render tree)
Given just the final ROP how do I, in python, get the list of all the ROPs direct dependencies?
I'm working on a custom render submitter.
I know I can run
 hou.node("out/r").inputDependencies()
to get the full list, but that doesn't give me the dependencies of each node in turn.
I figure I'll probably need to write a recursive function to spit these out. Something that runs over each subsequent list of dependencies until there are none then return the list. Somehow.
But maybe not? I imagine there might be an internal to Houdini way to do this, no?
Edited by kleer001 - May 8, 2019 19:51:15
“If you can eat it raw you can't under cook it”
Do you mean the nodes directly connected to your Rop node of interest? If you want the first-level dependencies, couldn't you just also run RopNode.inputs() and check that each node in inputDependencies() is also in that list?
The ‘render -p’ hscript commamd prints dependencies out with a lot more control over the format. It gives each job an ID and a list of IDs that job depends on.
ill +1 this RFE (still not in 19.5)
Might be nice to have multiple dependency lists returned from `inputDependencies()` akin to `render -pF` ids rather than a singular flat list of all `render -pF` line items. For example, the last node in each sublist represents a line item from `render -pF` and the line item id order resolves to the dependent rop object order in that list.
