BUG: Objectmerge and Mirrored paths
   4757   4   2
Possible Minor Bug
Houdini: 8.1.796
Distribution Build: Windows
Objectmerge seems to have problems with mirrored paths
A path mirrored in the OBJ scope is not merged correctly into a SOP with Objectmerge. The mirroring seems to be undone.
OBJ Paths
SOP ObjectMerge
A computer is almost human - except that it does not blame its mistakes on another computer.
Make sure you have “.” (dot) as the value of your Transform Object parameter.
edward
Hi Edward,
I'm not sure what you mean.
What I did is, I used the mirror function and then with an Objectmerge I merged the convertSOP (from the path OBJ) in the rig.
Which transform of which node should I check?
In Object Merge SOP, the first field parameter Transform Object insert a “.” dot
Time to get out of this messy world.
Here's a .hip file demonstrating using . as the Transform Object's parameter.
mirror_objmerge.hip (46.1 KB)
