Simple mesh baker outputs all black textures!
   3025   7   2
Hey everyone,
I am trying to use the simple mesh baker but the textures I get out of them turn out black!
I have tried a cage mesh and increasing ray bias up to 0.3 and still nothing. Both object are very high poly, and the topology doesn't match up exactly. But it should work. Anyone know any solution?
Windows 7| 24 GB RAM DDR3| AMD Athlon X4 760K Quad Core Processor 3,8 Ghz | Nvidia GTX 970 4GB
Here are the pictures. I had some issues uploading them
Edited by Yehbe - May 16, 2019 04:56:53
Moin,
doesn't look high poly at all to me :-D
Joking aside: First of, you probably need UV maps. You also need to check which way the virtual cameras are looking. If your higher resolution mesh is OUTSIDE the low resolution mesh, the camera bias needs to look “outwards” - et vice versa.
You may also have to play with the projection type (I cannot remember if the simple baker has that option, it's about “closest point” and “uv projection” etc).
There is a new “games tools” baker available that is said to be “much better” (https://vimeo.com/334054222 [vimeo.com] ).
Personally, I haven't had much luck with any of the bakers in Houdini recently. I had all kinds of clipping issues, direction mismatch (with displacement), lack of UDIM support etc. (so I wrote my own baking tools) - subscribing to this thread for that reason, since I would love to use Houdini for this kind of task.
Marc
Good bye.
thanks I'll check it out
File “<stdin>”, line 1, in <module>
File “opdefgamedev:op/sop_maps_baker?PythonModule”, line 4, in Render
File “CPROGRA~1/SIDEEF~1/HOUDIN~1.416/houdini/python2.7libs\hou.py”, line 10279, in cook
return _hou.Node_cook(*args, **kwargs)
OperationFailed: The attempted operation failed.
Error while cooking.
I get this error, any idea what it could cause that?
Argh … Python!
You may have to file a bug report for that, I am afraid. SideFX' support usually is rapid in responding.
(The more of Houdini is done in Python, the more cryptic and user-hostile error-message will become, I fear :-( )
Marc
Good bye.
I have gotten it to work! Another question though, I want to bake the whole sequence, is there an option for that or do I have to go into solvers or something to get it done?
Yehbe
Could you maybe elaborate a bit on how you got it to work? What was the problem in your case? That would maybe help others in the forum. I also only get black textures.
